Background;
New Predator(JD brand) blades,
level side to side,
new belt,
spindles turn freely,
Problem:
Three seperate cut paths. Not uniform cut. Looks like I push mowed 3 rows.
Suggestions? :banghead3
Never thought of that, good point. :fing32:Can you be more precise? That comparison will be interpreted differently by everyone and is not very descriptive.
Does the center blade look to be cutting grass longer or shorter than the outside blades? Are all three blades cutting at different heights?
What do you observe when making two side by side passes in the same direction? How about when the two passes are in different directions?
There was someone last week that had a replacement spindle that was different in size from the original.
