Why remove it ?? Its not that hard to fish the wires through..
Why remove it ?? Its not that hard to fish the wires through..ok i am going to replace the wiring harness on my 8n, the wires are just old. They are in the metal tube that runs down the block my question is when i go to remove that tube will the blots that are holding it to the block need to be torqued like a normal head bolt would, or is just to hold that tube on to the tractor.
well i not only did the wires need to be replaced but i think the one bracket that goea to the tube has rotted off and i was going to braze/ tach weld it back on thereWhy remove it ?? Its not that hard to fish the wires through..
That is also what I did. I could not get all the wires back into the tube. It works fine.fishing the wires through didn't work for me.
i got to the 4th pug wire and i didn't dare put to hard to wreck my new wiring harness.
after my effort i just zip tied the new harness to the outside of the wiring loom.
Fish mine through about 3 times over the past 12 years..No problem..That is also what I did. I could not get all the wires back into the tube. It works fine.
Red
