1 - 7 of 7 Posts
Unless you have adjustable tie rod ends you can't.
If the wheels aren't straight more than likely something is bent.
On my '67 1077, the right side tie rod has a threaded connector that can be adjusted in or out to align the front tires. If yours is missing this feature, maybe you could pick up a set of front tie rods for a 1077 or 1277. Perhaps only the long wheel base tractors had that feature??
Can someone tell me how to adjust the front wheel alignment on a 67' Wheel Horse 877 Automatic? Thanks!:thanku::greendr:
If you can post a picture it would help have you removed and replaced the tie rods or any thing to the axle ???
I have not messed with the front end, other than cleaning the grease off, and inflating the tires after it had sat for a while. I dont have adjustable tie rodlinks, but i could put on a new set i guess maybe? Need a length though. Thanks.
All the wh of that year and a few years before and after used the same tie rods unless some one put the on incorrectly its hard to get them out of aline now one can be bent but you would see that
How about a picture
1 - 7 of 7 Posts
