1 - 6 of 6 Posts
Hello, looking for parts for my mtd 860 1200 tractor, in particular the ignition switch (725-129) and the instrument panel (305-9584). The instrument panel I’m gonna try to salvage with some repair but the ignition switch is a different story. Can’t get the key to turn even after soaking in parts cleaner for a week. I can’t use a standard switch, it’s a generator/starter with 3 leads.
I moved this thread to the main MTD forum, hopefully you'll get more action here. ?
There is a switch on Ebay MTD 140-760 10 Ten Hundred Tractor Ignition Switch | eBay
You may also use an MTD 725-267. It is the switch used in later models, 1971 and after.
Also 725-0267 and 925-0267 will work. There are 5 terminals but you can use the three you need - M (magneto) B (battery) S (starter).
You're welcome.
1 - 6 of 6 Posts
