First order a copy of TM1360 from John Deere...
Then go to Section 250 Power Train Operations and Tests
but I digress...
When you engage the PTO lever does the light come on?
(Pages 240-15-8 and 240-15-9 covers the PTO CIRCUIT OPERATION)
You could lift the seat and pull UP the OPERATOR OFF SEAT PLUNGER , make sure your PTO selector is for the REAR ONLY and then try to engage your PTO ...what happened???
NO light...did you check your PTO magnet and TDL module?
Assuming the light comes on and the PTO shaft does NOT turn...keep reading...
How to adjust the PTO Lever and Lever selector
1. Remove left wheel and fender
2. Make sure lever is in the OFF position
3. Disconnect the PTO valve linkage.
4. Pull the PTO valve arm and PTO rod REARWARD.
5. Turn yoke until hold-in yoke aligns with hold-in arm.
6. Connect PTO valve linkage.
After adjustment go to step 7 group 5 (page 250-05-3)<<If you fail to operate you're back to here...
If PTO still does NOT engage/disengage.
Disconnect adjustable link from arm on side of transmission case and shift by hand.
If PTO can be engaged /disengaged properly, external linkage is binding or out of adjustment.
If arm moves but does not engage/disengage PTO(s), PTO linkage is not shifting PTO selector valve (hydraulic valve problem).
If the selector shaft in the side of the transmission case is stuck/binding: Try to free up by operationg arm with vice grips or large pliers.
If still binding or rotates hard, it may need to be driven from case to clean/service.
USE THE FOLLOWING PROCEDURE:
1.Drive spring pin out and remove the arm from the shaft.
2.Remove PTO cover from rear of transmission.
If needed, rotate shaft so that the inner arm on the shaft clears the PTO reduction shaft.
Drive shaft from INSIDE of case and remove.
Clean/service and reinstall.
IF PTO STILL DOES NOT ENGAGE,
DISASSEMBLE TRANSAXLE (See Section 50)<<<You better have the manual at this point...
AND INSPECT FOR:
Damaged PTO valve or selector lever linkage.
Damaged PTO valve.
Damaged PTO clutch pack.
Damaged PTO brake pack.
Damaged PTO gears or shift collar.
