CRL
Discussion Starter #2
Removed the two stage blower and used the front hitch off a 2305 started the mounting process. I used a mounting bracket off a 1025e for attaching the top front hitch and used some home made 1 1/4 flat steel brackets on the side for mounting.
CRL
So I've been working on this project here and there and now have an update. The front bracket was made to attach to the existing 855 pto bracket mount on the tractor. The newer quick hitch attaches to it and I am able to use the 47 or 60 Blade with it. So far impressed and moved some snow with ti the other day. Now I am working on a 52 broom to use with it. Broom mounts up but had to have a new drive shaft made for it to slip in since the older one was way to short. New one was made with quick coupler at $154.00 by local drive line shop. Im in the process of putting it together and putting new bristles on broom.
