1 - 10 of 10 Posts
Gradually getting closer to finishing the goal of mating an old rear tiller to a new-to-me 816S. Got the rear PTO installed and fired it up for the first time today (see video).
I'm surprised a bit by the amount of back and forth movement in the shafts and the gear box. But this is my first time working with the rear PTO set-up, so maybe that's fairly normal?
Curious as to what other think.
Thx!
Neil (jeepagain)
It seems like the set-up would benefit from an additional bracket to support the gear box, say from the frame down to the outer edge of the gear box. I wonder if anyone has every tried that.
-Neil (jeepagain)
Does your setup use the hook or angle bracket to secure the gearbox to the frame? If it is the latter, snug it well with a nylok and all should be well.
Sent from my SCH-I605 using Tapatalk
I've got the hook. I'm going to explore making/using something to make it a little more secure.
Sent from my iPhone using Tapatalk Pro
Also, I found with the angle bracket setup, I had to add washers to take the play out and ensure proper alignment.
Do you have any pics of what the angle bracket setup looks like installed?
I can snap one of just the angle bracket tonight, as this is basically a permanent fixture on the 16G now. The hole location in the frame may well vary since you are dealing with a short frame.
My next step with this setup is to make a suitable gasket for the gearbox halves, as I have a "leaker" and not sure where it is coming from.
Can anyone recommend a suitable gasket material for this?
Discussion Starter #9
Update: I went ahead and made a bracket from 3/16" flat bar stock. Replaced the pin with a bolt (keeping the hook in as well) and everything is MUCH more solid now. No more gearbox flopping around like a fish...
Nice work. Looks sturdy now.
1 - 10 of 10 Posts
