The clutch should be adjusted while the arm is in the neutral position. At least that's how I did it.
You are adjusting the clutches (plural) on both sides? Right?
I don't mean any disrespect in asking.
This is correct. And yes, there is only 1 clutch on each side exactly how you describe it. I was just checking. If one side is way out of adjustment it might affect the operation of the other. Your reference to "the clutch" prompted my question.None taken... actually I thought they worked independently from one another... the right side is forward and the left is reverse. How would one side's adjustment affect the other?
If those two pictures show the clutch with the lever forward and with the lever neutral, then your adjustment is way off. In neither case is the clutch disk engaging the clutch hub.Below are pics of the clutch ... the first one is with the for/rev lever in full forward position... the 2nd pic is the for/rev lever in the neutral position. The tractor doesn't move with the current adjustments. What am I doing wrong?
http://www.jpmill.us/gravely812/clutch1.jpg
http://www.jpmill.us/gravely812/clutch2.jpg
Glad you got it figured out. You still have all three cam rollers too, right?
