Ok guys iam obviously new to this forum but here are my questions!
I just brought home an 801 Powermaster that i got from my grandpa. It used to run about 5-6 years ago but we stoped running it because as it would get hot it would shut down! Well it sat outside for about 4-5 years and suprisingly is still in pretty good shape! The tractor has a stack on it but had a flapper so hopefully not too much water has made its way in!
I drained the oil and it did not look bad at all! Took the spark plugs out and stuck a screw driver down the holes and it does not look to good at this point! There was some moisture in there as well as some black crude, I can not get the engine to turn over as of now with a wrench on the PTO.
Next thing i did was take the valve cover off. I would assume i need to adjust the valves at soe point but the oil under the valve cover is super sludgy! So i may run some diesel down the through the engine to try and clean her out!
I guess really i would just like to have some tips on this tractor maybe some specs and a good place to buy fairly reasonable priced parts!
Thanks in advance!
Thanks in advance!
