800 forward reverse lever set screw
1422 Views 10 Replies 5 Participants Last post by  gm1276
I can see this set screw in my cast iron lever, it is missing the jamb nut, and I can see it on the parts diagram. But what is it for? Is there supposed to be something on the frame that the set screw should set up against? Maybe to hold the lever in the upright (and locked) position? The green covered parts list from oldgravelys has the set screw as part # 102623 and the jamb nut as 120238 for those who are watching. I don't see anything on any diagram (or on my tractor) that goes into the frame hole adjacent to the screw.
1 - 11 of 11 Posts
The set screw is supposed to contact the neutral safety switch. The neutral switch is a good item to have functional. The set screw is in contact with the neutral switch in the picture below. Now that I think about it, a neutral safety switch is a very very good idea. Given the power of a Gravely, one could wind up through a wall before it got stopped.
Thanks, Richard!
Anyone got an extra neutral safety switch lying around?
I don't think I've ever seen an 800 series with a functional interlock switch! Or even one that was there. Learn something new everyday. I will double check if I have any for you, Ralph!
I keep them all working on my tractors. Never hurts to be safe. If your tractor is running and you do not have one, the wiring has been messed with underneath. You may also need the pigtail.
It appears the switch was added at some point. My 814 doesn't even have the provisions for one.
The switch in the picture is on my 818T.
I forgot to mention that is works too.
The wiring diagram shows 2. One for the lever and another for the PTO. My 810/816 came with a horn attached to the bracket where the PTO interlock should be...
No. The horn does not sound when the pto is engaged.
Yep. Check out the early IPLs and you will find it is absent. I will have to double check the 816 when I get home, but I feel like it does not have one either.
1 - 11 of 11 Posts
