Sounds like it'll need a thourogh cleaning first,then you can diagnose the problem..it's probably gummed up with shellac and though you might get away with putting some Seafom in the gas tank and running it awhile to let it work in,I'm betting the tank and carb will need to be cleaned good with carb cleaner or acetone,,then adjusting the mixture will have some effect when you try adjusting it....as it sounds now, the carb is half clogged, and only the idle circuit is working..
