Mine is in the the hole to the left of your hole.
Where did you get your carburetor?
Its the same carb, just dumped an entire can of carb cleaner on her to clean her up and replaced all the rubber with a factory $15 kit. She runs like a champ now. You are probably running into the same problem I was about finding a new carb. They just aren't available. I stopped by two shops locally and checked a handful of online dealers, they all said they could get one, but when I had them check -- sure enough, no luck.Mine is in the the hole to the left of your hole.
Yes I could not find a new one. My carb was broke because someone hit something with the tiller and it could not be fixed.Its the same carb, just dumped an entire can of carb cleaner on her to clean her up and replaced all the rubber with a factory $15 kit. She runs like a champ now. You are probably running into the same problem I was about finding a new carb. They just aren't available. I stopped by two shops locally and checked a handful of online dealers, they all said they could get one, but when I had them check -- sure enough, no luck.
Thanks for the reply, I'll move the wire over one hole.
