1 - 1 of 1 Posts
Installed new oil seal on left hand side but new seal does not fit flush in rear end housing. I have the correct seal, used the cross reference chart for the Bolens number, it is the same size as the original also, just does not fit flush. Is this normal. Besides the new seal is leaking. The seal was not damaged on install as best i can see. Is there any common problem that causes the left side to leak??
1 - 1 of 1 Posts
