Hello all,
first let me explain that when I got the tractor it had exactly one wire. the alternator wire.
Next let me explain that my gauge cluster looked like someone took a hammer to it.
all that to explain that what im tying to do is judge the health and functionality of the tractor without spending money on a bunch of secondary parts. so what im doing is wiring in a dummy light to the oil pressure switch.
my guess in the switch is the original one from 1974.
I wired up a dummy light as per the diagram. when in turn on the toggle switch (i put this to save the battery when not in use) the light comes on. the tractor is not running.
i start the tractor, the light almost immediately goes out... then a 3 to 5 seconds later it comes back on. tried it 5 or 6 times and always does the same thing. Do yall see anything wrong with how i have it wired?
Im guess and HOPEING that its just a bad oil switch as i ran the tractor all day Saturday, this is also what make me pretty confident that its the switch. don't think it would have ran all day in 91 degree heat, bush hogging, without oil pressure.
Thanks
Wiltz
Thanks
Wiltz
