Hello all, I've got a '73 jd 112 that I adjusted the variator on ( lever in 5th position, loosen the front cap screw, turn over the engine to raise pedal, tighten cap screw). Now the variator is working correctly in 1st position, but the clutch pedal goes all the way down, and at its highest is 5 3/4" off the footrest. In the manual I have (from '69) it says to adjust the clutch override until i get 3/4" of clearance off the footrest, and a max height of about 7", but I don't see a clutch override. I looked up the part to make sure of what I was looking for, and all I have is two flat steel pieces for a linkage where the override should be unless i'm mistaken? I can get it to shift if I hold a little pressure on the shifter and then let the pedal out about an inch, then it will pop into gear, but occaisionally that grinds a little bit, so im looking for suggestions on how to get it working right. Any help would be much appreciated. I'll try to attach some photos of what i'm looking at. As a side issue, the brake pedal (on this model the brake is on the right and the clutch is on the left) is reluctant to come back up, and I can't seem to locate a spring that returns it to position, where should this spring be? If anyone has a diagram of the brake and variator assemblies for this model, that would be really helpful.
Thanks in advance for any help!
