I was driving around at a tractor swap meet and the engine started to knock and loose power brought it home and pulled the head off and theres oil on top of the piston so either bad valve guides or cracked ring well valve guides are tight so....... the engine was freshly rebuilt with rings and piston from Briggs and Stratton so if the rings are cracked im going to be MAD! but I got to pull the piston out first well other than that I bought the right shroud for it so not all bad of a swap meet.
