1 - 9 of 9 Posts
so my 7116 has no spark, this is the model without the points on teh side on teh engine, where do I go from here? any help would be appreciated, I've searched but didn't really know what to search for if this has been covered.
thanks
John
I just put one together like that. Pull the tin and check the gap against the flywheel. Ignition could have gone bad or something grounded out...
I thought something like 30 thousandths. I used an index or business card when I did mine. WOW does it have spark!
Discussion Starter · #9 ·
turned out to be a wire, somethign is causing the system to "ground out" all teh time, take the ground out wire off and it runs... seems to be some type of relay that isn't working right now...
1 - 9 of 9 Posts
