1 - 12 of 12 Posts
i have chewed through 2 starter bendix gears in about 3 days. why is this happening. the starter is brand new?
Senior MTF Poster
I am sure others may know WHAT ENGINE you are talking about but I sure don't and IF I knew, I might be able to help.
Walt Conner
The first 2 things I would check is that the ring gear on the flywheel is in good shape and not all burred up. Next I would check carefully the alignment and engagement of the starter. It may need to be shimmed in or out a little. It might be binding up and not allowing the starter to fully retract once it is started.
the engine is a briggs 16 hp horizontal drive. engine number 326437 - 0252. the flywheel is in good shape. you are right in that the starter does not fully retract.
i did some investigating last night and i wonder if i have the right starter. it seems as though there are two, one being slightly shorter .
i need to confirm that i have the right unit before i start asking questions about shimming.
Can anyone tell me the briggs part number for the starter.
Here are the specs for starter for your engine.
one or two more starts and the 3rd bendix will be worn out AGAIN? please someone tell me what is wrong?? :banghead3 :banghead3 :banghead3
Senior MTF Poster
OK, I have not had one of those engines with a bendix type starter. What kind of ring gear is on the flywheel? What is it made of, aluminum, steel, cast iron?
I have a hunch that it is steel or cast and you are using a plastic (nylon) starter gear.
Walt Conner
Discussion Starter #9
walt, the old one was clearly not nylon, however i left it with the starter guy to order me a new one and we both decided i did not need it back. the pinion is nylon. i have no idea what the flywheel is made of, how do i tell? are you certain that the 16 tooth gear is correct. i have also seen some 14 teeth gears?
while i am getting attention , the engine runs great for a while and after about 20 minutes it starts to bog down and then i have to choke it to stay running and then after that the engine starts to fade quickly and eventually quits. let it rest for 30 minutes and same thing. before i spend 160 on a new carb is there a good carb cleaner?
Discussion Starter #10
can anyone tell me what the flywheel is made of on the 16 hp briggs that came on the 7016H ? how many teeth are supposed to be on the starter bendix? the starter has gone through 3 nylon pinions. the flywheel appears to be in good shape and the starter is on straight.
Discussion Starter #11
thanks for the help so far. can anyone tell me the starter gear tooth count as well as the material of the flywheel.
Discussion Starter #12
7016 belt allignment
the engine is cast. so i will replace with metal pinion gear.
also where should the mower belt be located on the PTO clutch?
whatis the best carb cleaner ?
thanks
DA
1 - 12 of 12 Posts
