This ought to be a no brainer but I'm stuck and need your help.
I put the 7-iron deck on the other day in hopes of doing some grass cutting. I had the deck stored up on 2-wheels as many have via this forum.
Today I started mowing and noticed something that seemed out of whack to me. The 4 mower wheels seem to be going in every which direction. I got the manual out and it says this:
they all need to face forward and then you "lock" them in place by lowering the quick release pin. I tried that but the release pins don't end up in the holes along the shaft of the wheel. They sort of stay in place but not really when I am mowing. If I lock the quick release pin into a hole on the shaft, here is what they end up looking like. Sequence is: Left front, left rear, right front, right rear.
As you can see, none of them are really straight to the mower. Picture #2 - the left rear is really out of whack. Now I do need to say that when I put the wheels back on after being off during storage, I did not pay attention to if there was a "left" wheel or a "right" wheel. Maybe there is. The front wheels never came off so this is how they were when delivered. The right front wheel is close but the left front is not close to being straight.
Seems to me this out to be simple but I'm stuck. If I set the wheel straight and lower the quick release pin, they don't stay straight while mowing. Once they start to hit the ground for whatever reason, they start to move around.
Are your wheels pointed straight ahead? If they are, are your locking pins actually sitting in a hole in the wheel shaft?
