hi first time in big tractors im and old cub narow frame guy but had the chance to get a 57 farmall with one arm loader i would like to change to 12 volts all that i've read says to use an alt my ? i have a complete set up for a cub 107 could i just exchange those parts gen voltage reg and coil it looks like i'll just have to make a one inch spacer for the gen thanks you for the help
The 107 has a starter generator. You can convert to 12 volts two ways. Either
put on a 12volt generator or alternator and the appropriate regulator. You won't need one if you use a GM one wire setup. Or if you want it to look original you can simply put on a 12 volt regulator with the generator you have, it works I did it on a JD B. I believe you'll need an "A" circuit regulator. You'll need to switch to 12 volt bulbs of course.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
My Tractor Forum
