1 - 20 of 37 Posts
Murray tractor owner
My local dealer has one, no mower deck, runs and drives great, and wants $500 is that a good deal, it needs paint and a tune up (I will do the tune up and paint it) Can you get a 3pt hitch for these?? it looks awsome!!
Depending on your ser# Before SER 719,999 it took a IH 3point Hitch which is not a Cat 0 3point hitch Which you would then Put a brinly Sleeve hitch Adapter on. After Ser# 719,999 it could take a Cat 0 3point hitch with spring assist.
IH 3point and Brinly Hitch
Cat 0 3point with spring assist
MTD parts number for Cat 0 3point with spring aaasist:
190-388 for ser# 821,101 and Below
190-389 for ser# 821,101 and Above & you would need 190-309 manual lift assist
IH cub Cadet 3point hitch:
MTD part Number 190-381
Brinly adapter
MTD part Number 190-386
http://ihccw.com/IMG_2615_10.JPG for a 682 about $300 used through link below
http://ihccw.com/sleevehitch.html
You can still get the IH cub Cadet 3point through MTD
I hope this Helps on your 3point questions :thThumbsU
Thanks sergent, Now is $500 for it a good deal??
Yes since it's running and No deck that fair.:thThumbsU
16 horse briggs I/C I think.
TractorData.Com lists the 682 as having the infamous Kohler KT17, I would check to be sure it has full pressure lube.
steve
Discussion Starter · #9 ·
steve
Is it a good engine??
Discussion Starter · #11 ·
Series I, not so good, Series II, OK. Just do a Google search for Kohler KT17 and read up on it.
steve
Ok I hope it is good, I could re power it when some thing happens.
Discussion Starter · #13 ·
If wanted to you could put the Cat 0 hitch on it no matter what the serial number is. Eventually if you upgrade the motor you could even put in a Mag18 you'd just need to modify the wiring. Very easy change.
Discussion Starter · #16 ·
Has any one ever put a onan in one??
Discussion Starter · #17 ·
Are they a hydrostatic transaxle?
I thought 682 where 3 speed versions of the 782 which was a Hydro. I think the 582, 682, 782, and maybe even the 982 shared the same body/'frame. The 582 being the 16hp Briggs twin, geared, the 682 Kohler KT17 geared, the 782 Kohler KT17 Hydro, 982 Onan 20hp Hydro, can anyone confirm this?
982 had a longer frame. It's basicly the First super Garden tractor:thThumbsU
1 - 20 of 37 Posts
