1 - 3 of 3 Posts
JD318
680541 L-series drive
I have the belt-drive on this mower that creeps all the time and is hard to pull backwards when the engine isn't running. I've tried the adjustment procedure from the manual, adjusting the nut on the cable by the handle, but it has made no difference. Is there something else to adjust?
JD318
Discussion Starter #2
Well by looking thru some older posts, I guess I'll try to get the gunk out of the tranny and lube up the cable. Should've did the search first....
yep - a good cleaning and re greasing is the cure. warning -its a very big job-but the only cure-mine works like new again
1 - 3 of 3 Posts
