1 - 16 of 16 Posts
Gravely1964
About September or so I went and picked these up.
Back story fella on facebook posted on the groups seeing if some local would be interested in them. They were his dads and he just had no interest or abilty to work on them.
DSC00665.JPG Me Big Red and the 5.5 by 10ft trailer are at it again
DSC00662.JPG What im calling a 67 430 trans and motor with a newer frame. With supposed trans issues. Will get to that here.
DSC00661.JPG Lots of stuff
DSC00666.JPG Decks parts and stuff
DSC00667.JPG Commercial 12 drove on the trailer :D Plus sprayer, square shoot snow blower, plow, and a kit form 71 432
DSC00669.JPG The 430
DSC00668.JPG Commercial 12
DSC00670.JPG Other 432 trans
Haul vid. Unloading seeing the 430 issues. Going threw and putting things away
Gravely1964
Discussion Starter #2
DSC00680.JPG Sprayer, blower ect and 430 in the shop
DSC00694.JPG Other angle with the C12 battery chargeing
DSC00708.JPG Moveing stuff around makeing room to pull the motor off the 430
Figuring out what my issues might be
DSC00733.JPG seat pan off getting ready to pull the motor
DSC00735.JPG When I pulled the motor I had no idea what was in store for me!
DSC00737.JPG Literally drove it into the shop on one gear!
DSC00749.JPG Total and utter carnage of a high low planetary gear set :14_6_5:
The carnage
DSC00743.JPG In the haul there was a spare high low planetary
DSC00755.JPG Put it in
DSC00758.JPG Put motor back on still no high gear :crybaby: :maddd: I walked out the shop that night wishing I had sold it the way it was. While inside that night pondering. I thought it has to be the high side key way sheared on the crank!
The first round going together.
Finding out what was wrong. My disappointment can be heard
Pulling the input gears
DSC00767.JPG Most of you know I don't give up so easy. When I pulled the motor the next night. The rear gear spun on the crank. It was an all out battle to remove the gears. But im a fighter and won.
DSC00774.JPG But still was not out of the woods yet! When I went to put the gear back on with key there was so much play realizing the crank was worn from the gear spinning on there :crybaby:
Heres the vid of that
DSC00802.JPG My only hope was the new style on piece gear to work off the good keyway and gear surface. An ebay order for the gear, and adjustable reamer and bushings for the high low plantary
DSC00806.JPG New gear installed
take it apart
DSC00814.JPG Re bushed and reamed to fit
DSC00819.JPG My first planetary rebuild
Putting it back together
DSC00823.JPG I put her together that night and drove it out to the truck in the dark to take and pressure wash it the next day :dancingpa It worked perfect and one of the quietest 400 transmission's I own now
The final except for an 810 hood I added later
DSC00919.JPG For right now thats it on the 430. till I get the early frame and trans to match the 67 year in February or so when I go out to my buddies for the blow in
Gravely1964
I wish I had half of your skills and knowledge...
Thanks. Alota as my uncles called it the school of hard knox. Learned it all from doing it. And good portion from my grandpa, uncles, electrical from my dad.
The partial gravely stuff came from the older guys posting and fixing things. And I've soaked it up like sponge. Hence the reason I post of fixing and working on things. I know i've inspired others threw my video's and posts.
Great work, and congrats on your first planetary rebuild, Steve! When I get more time I'm going to watch your vids, but seeing your pics told the story too. Guaranteed your transmission is more quiet than my 430's too. I saved my old planetary when I put the new one in several years ago. It's around somewhere just in case.
Nice haul too, BTW.
Just back from watching your last vid. I had to see how it sounded. I couldn't hear your trans. at all! You really *do* have a hard decision to make if you're going to keep it, or not. It's a nice tractor.
Gravely1964
This work here was pretty recent last month or so.
First time trying the commercial 12 out. Clutch rods were outa adjustment.
DSC01012.JPG Threw a deck on
DSC01018.JPG Changed de trans water out for fresh oil.
DSC01029.JPG Went out and tryed it out
Worked pretty good
Gravely1964
Discussion Starter #8
Gravely1964
Discussion Starter #9
Nice haul too, BTW.
Thanks Dave. Up till this point just never had a reason or need to rebuild. But no time like the present.
Was a decent haul. If I didn't mention it above I only gave 300 for this whole lot of stuff
300 for everything just made it a *great* haul!
Steve, about that C 12 of yours. Does it have locking reverse as set up? Mine has another set of holes. That switches it to locked out reverse. Using another style shifter. I've seen other C 12's set up that way. I don't recall seeing it in the owners manuals, but maybe its in them some place....
Gravely1964
Discussion Starter #12
Ok think im getting this new setup up mtf has done figured out. Goods and bads I feel.
But regardless I'll say late September or so I went and picked up the motor for the 432 in kit form. Long story short forgot about since it was over in the neighbors garage
Threw my parts motors I was able to put it together enough and see what it would run like
Seemed pretty good here
The other 69 432 had a smokeing and knocking motor. So stuck it on there
Once it was on the tractor found out it to smoked. But as a plus no knock
Already 30 over and piston very sloppy in bore. Be good candidate for a 40 over rebore perhaps
Gravely1964
Discussion Starter #13
So just got back around to the commercial 12 drive issues. Shifter arm worn giveing it alota of slop
Even the keyway, what its suppose to look like, and what came out
So when I went to put another arm on. I broke the bolt that holds it on. Spent a full day getting it out then breaking tap off in it. Plan B is the new style with clamp bolt makeing the bolt in the end not to important.
Arms off of ebay I bought
Old, what I put on to see it work right, and new and improved style
Keyway and notice broken tap?
New arm installed
So while working on the bolt noticed it leaking gas
Found po had patched the tank. Was perhaps solder or perhaps lead. Unsure and didn't want to mess with it. Had just a pin hole near as I could tell
All the crap I scraped off
Jb welded. Waiting for jb weld to fully cure. Or could have been outa the shop tonight. Oh well maybe tomorrow
  • Like
Reactions: ultane
Gravely1964
Discussion Starter #14
So with a recent blow in trip behind me. On the way stopped and picked up another 67 430. Missing a few things, but enough left for me to make one outa 2
In the bed of the truck at the hotel that night
Pretty sure it 22927
So got the front tires on enough to roll it off the truck and carry it out back with yanny
Got an left hand spindle on the way from ebay. Long story but put a riht hand one in the left lol
Im trans and motor swapping, one out
2 out
Did not take a before but wire wheeled alota of the red off the trans
Trans and motor bolted in the frame im gonna use for 67
Decided to bolt the other trans up just to roll it outa the shop
Outa pic room on this post, too post 2 on the 67 430 build outa 2
  • Like
Reactions: ultane
Gravely1964
Discussion Starter #15
So after doing the electric wireing ect. Was not charging. Only had 4 ac volts from stator. Pulled flywheel and theres your problem not enough magnets left. Theres some good ones on ebay. But don't want to spend the money at the moment. Gonna replace blower shroud as well. When it comes back apart
So with that all done my next improvement is cage nuts from mcmastercarr. I'll do a separate thread on these babies in abit here
My way to aline both sides to make them close to straight up and down. There a pain to install if you don't do so
Hood on. Im going to leave the grill out to hook up a trickle charger for now
Custom shift plate that came with it
Added flywheel screen, tool box
Seat pans on
Think its a very decent first year 430.
Pretty much a before and after shot. You'd have never known there was a 67 under there
  • Like
Reactions: ultane
Yep, it looks like the grille is denying access.....
Is the wall retractable?
1 - 16 of 16 Posts
