I took the resistor out,same problem.There has got to be something I am over looking.It already had the 12 volt system with points.I left the key on and when I started to crank it a few days later the battery was dead. Charged the battery would not crank. I figured it burnt the points, So I figured good as time as any to swap to Electronic Ignition. I got a Pertronix Ign. put it in like instructions said. I can get fire in distributor cap but nothing thru plug wires. plug wires about a yr old. Checked wires everthing is connected good. What am I over looking. Thanks in advance.
See less
