I've had the X485 for a year now and love it. Smooth abundant power. Clean burning. Fuel injected. Ability to easily handle 3 point implements, like a rear blade. It was everything I wanted in a tractor when moving from the 318.
Since I bought it used, I took the mowing deck that came with it, which was a 62C mowing deck. I thought the extra foot in cutting width would be great since the machine had the power to turn it.
I have found that the X has no problem spinning the blades through all manner of grass. The shaft drive really helps.
On the other hand, it is heavy to mount/unmount and move, and with the extra width and the variations in my yard surface, it is hard to get as even a cut as the 318 had with the 50" deck. I also can't fit between some yard obstacles I previously could.
Knowing what I now know, I would have opted for a smaller deck. It would have taken 10 or so minutes longer to mow the lawn, but it would be worth it.
Bigger isn't always better.
