I checked the battery (brand new) today with the tractor (8n) running and the volt meter reads 6.23 with the tractor at idle or almost full throttle. On the back of the generator there is a screw to adjust how much charge the generator puts out (I assume). Can I or should I turn this and increase how much it is charging? I thought I read somewhere that a 6 volt system should be charging at around 6.9 volts. I appreciate all and any thoughts. Thanks.
Red
Red
