1 - 3 of 3 Posts
An I&T shop manual, available at any local Tractor Supply, is a MUST for a tractor owner. They usually run around $35.00 and will give you all of the torque values as well as the sequence.
Joe
Can anyone tell me where I can find a chart for 1983 ford 5610 tractor torque setting on the head. Will be replacing it soon and cannot find what the torque is!!
Not sure if you still need this info but replying anyway. IT manual states to torque head bolts in 3 steps as follows:
1st: 90 ft lbs
2nd: 100 ft lbs
3rd: 110 ft lbs
Start in the middle of head and work outward alternating left and right. Hope that helps.
1 - 3 of 3 Posts
