I'm looking at buying a used 1023E without any mower deck. I found a 54D green belly mower with auto connect. Does the 1023E need any specific parts to make it auto connect compatible or is that just literally plug and play? Thanks!
They are not plug and play, if the tractor had auto-connect there is a driveshaft autoconnect coupler on it, if not you would need to add it, cost for the coupler is about $550.00.
You need to make sure you have the remainder of the parts to hang the deck on the tractor. The auto connect to pto is only one piece of the equation. I see many decks for sale without the rest of hardware. If you are not careful you will spend more for a piece parts solution than new.
That answers it. I saw a 54 auto connect for sale for $800 that was nearly new, but didn't have any of the other equipment aside from what's built on to the deck.
