I really like the looks of those 10ford!:thanku:
Not at all. The snow glides right off when angled. The rubber on the wings does contact the grass on the edges of the sidewalk when angled. I think if I had not installed the rubber, there would be massive turf removal in the neighborhood along the sidewalks.I like those Wings! :thThumbsU
If I remember right, from past posts about them, angling the blade the wings don't bother the snow moving to the side?
That is just like I had them configured on my ATV. It helped the 48" blade grow a little wider while keeping the snow from spilling out. Same top flap too (handy for the deep fluffy stuff).I've had quite a few requests for details on my plow wings. They are Cycle Country brand. They attach with 2 bolts per wing. I added rubber to the bottoms to match the JD squeegee I have installed. Overall width is now 60". Hope this helps.
Alan
After 2.5 seasons and hitting a curb last year, no damage to report. I think the Deere blade is quite a lot thicker than ATV blades are.One thing that I did after the 1st problem (the wing hit something and bent outward wrinkling the blade where the two bolts are) was to install a piece of metal about 1-1/2" wide x 3/16" thick x the distance between bolt holes + 2-3" in length as a large washer. I bent it close to the radius needed, marked and drilled the holes, then tightened the bolts to snug it in place. I wish I would have done it before the damage.
The JD plow may be a thicker blade though so you might be fine as is.
