I no longer need this plow. It served me well that last few years. Everything works as it should. Bottom cutting edge is in good shape.
The hitch on it was made to fit a 455 frame using a rod at the bottom and 2 heavy bolts at the top. You could use a rod at the top also for quicker attachment.
The hitch goes up/down/left/right. Can be used for snow also, obviously. Local pick up only.
