Still on deck, put new drive belt and found I could move the drive pully too much lol...and I had been hearing a noise ( a new one!) lately......I had been told at one time they were re-buildable but I wasnt able to locate parts to do it.....new are still available but at $600.00 EACH!
The one I got was $329.00 (used but good) delivered......
But two were sold in one day, so if I can get parts, More than not I will sell it.......
Ok I have been using this guy hard for some years now. Something has finally let go... My son was moving some dirt with it and said it was moving fine, got off tractor, got back on engaged 1st gear moved a foot then it stopped moving... We towed it back to the garage and inspected a couple...
I plan to have two GT 3200s with Blowers and one with a plow this winter. I currently have a fairly unique weight/bracket on one of them, but need to fabricate for the other two.
The one I already fabricated works well, but I built it based upon materials I had on hand at the time so I will...
Hi, I own a 2009 Cub Cadet GT3200. My hour meter died a few weeks back and I purchased a new replacement that I thought would just snap in. To my surprise it does not and it looks like I will have to modify (cut) the plastic housing (back of the dash) to get the broken one out. Has anyone...
I'm trying to do some modifications to my lawn tractor to raise the height up a little bit, due to low ground clearance with the snow plow on. It currently has pretty small wheels and tires. 15x6-6 in the front and 20x9-8 on the rear. The fronts have roller bearings and are held on with e clips...
Finally got this running in a limited capacity. Still need to configure the 2.5" bore, 6" stroke curl cylinder I bought but I needed to grade the driveway so I'm using it with the pull-cord dump feature right now.
Running w/o the seat and fender loose to check for leaks after it got hot...
A forum community dedicated to all Tractor owners and enthusiasts. Come join the discussion about specifications, modifications, troubleshooting, maintenance, and more!
