I hace a 95 520H that's leaking oil onto my mower deck. I can't see where it's coming from. The engine is running fine just losing oil. Any Ideas as to where the oil is coming from? Thanks
well wash off engine around base and run sounds like the base gasket my be leaking hard to tell with out pictures
ChevellesRule
In the late models of the 520's they added an extension to the oil drain, over time they would loosen and would leak oil. I would check that first.
Could be coming from the crank case vent on top of the engine. It has a rubber boot clamped on. Could be too loose or has come off. The manual also warns not to tighten it too tight as it may leak.
