I just installed a water heater in the lower radiator hose on my '52 8N. I keep my 8N in the Upper Peninsula of Michigan. It doesn't like to start if it's 30 degrees or lower. I've read that this is a fix for this problem.
I decided to put in new antifreze, Prestone 50/50 Long Life and a new lower hose, just for good luck.
I know that the manual says capacity is two gallons. I have read here, several times to only fill the 8N until the antifreeze covers the radiator core. That this practice would prevent the 8N from boiling over.
So that's what I did. I'm just wondering...after covering the core and running my 8N for ten minutes...it only took about 1.5 gallons to cover the core.
Does this sound about right?
In advance, thanks guys, Double Ott :Tractor2:
