1 - 10 of 10 Posts
I had to do quick bearing change on one of my 50" mower decks last night. As a result is used up my stock of spindle bearings. I called Tony at Accurate Bearing and got current pricing for a Set-4. Set #4 consists of the cup and cone (L44610, L44643 combo). Anyway the pricing is as follows:
RB Tech bearings (China import) $4.50 each set
NTN (Premium) $10.00 each set
Other brands are available. These are the ones I happened to pick.
NTN owns Bower Bearing.
Gravely bug bit.
Timken Set 14 is right for those parts numbers. Timken Set 4 is L44649 & L44610. Set 14 is what is normally used on the 50". Set 4 is what is used on the front spindles/axles of the tractor.
Discussion Starter #4 (Edited)
You are correct. The set number is wrong. Set #14 is correct. I typo'd the silly thing.
Richard - who really does need some new glasses
Richard,
Do you know if these 50 inch deck spindle bearings the same bearings used in the 72 inch decks with the 6 bolt spindle flange?
Thanks,
Tom
Both decks use the same bearings.
Gravely bug bit.
40" three blade, 50", 60", 72" used the same bearings with many 40" TB, 50" and 60" using the same housings. Later 60" and 72" as used under the 24-G used a 6-bolt housing.
I Love All Color Tractors
Sorry for the delay gentlemen. As requested, this thread is now stuck and will be moved into the Gravely FAQ and Stickies forum at a later date. :fing32:
Discussion Starter #10
On a related note, the belt used on the 50" deck is a 1/2" x 126" belt.
1 - 10 of 10 Posts
