I started in mid September a new 4 x 4 excavator.
Quite simple but powerful enough: 4WD bobcat-style steering
Adjustable stabilizers at the front and leveling blade at the rear that can be used to level, lift the back and anchor the back when working with the backhoe.
Backhoe rotates 200 degrees with hydraulic cylinders and gear, 3500lbs pull force at the bucket
Lifan 2 cylinder engine 688cc 24 hp, hydraulic pump 12.5GPM
27 '' 6-ply tires (industrial machinery tires would have been too steep for the weight of the excavator, which is more important than the weight of a UTV vehicle)
All orders are adjustable in front of the seats (10 spools valves)
Valve to adjust the hydraulic flow without losing the pressure to have the right shoveling speed according to the work and the experience of the operator.
Speed control valve for downhill.
Towing on the road without the need for a trailer.
