I am in process of repairing my peculiar small tractor from 80's, which has hydrostatic all-wheel-drive with hub motors. In normal use all four motors are working parallel in a closed loop circuit. For slippery conditions there is "diff lock" kind of function, which is controlled by a hand valve. The the "diff lock" is made in a 4WD control block, where all the hub motors are connected. There is no documentation or schematics available for the block anymore, and I am not willing to disassemble the plugs and cartridge valves on the block. Therefore I'm trying to make reverse engineering by an educated guess.
The 4WD control block looks this:
In the upper part of the block there are two through bores closed with the big plugs visible in the picture. I assume there are flow divider/combiner valves between those plugs. The pressure lines for the hubs are connected right beside on both sides of the block. Additionally there is one through bore perpendicular in the middle of the block. For a perfect solution there should be a third flow divider/combiner to make all four wheels spinning at same speed. However I understand that there has to be the pilot operated spool valve somewhere for connecting the flow to the flow divider/combiner valves. Therefore my assumption is that the third pair of plugs hides the spool valve and there are only two flow divider/combiner valves.
Based on what I explained and what you see in the picture, would this schematic diagram make any sense? The port codes on the drawing are same as stamped physically on the block. I omitted the hub motor leakage lines from the picture.
Or can there be such flow divider valve cartridge, that have an integrated pilot operated control to enable/disable the function? Then there could be proper three divider setup.
