In addition to my post of October 2021 - 1996 Murray the issue of the mower moving slow still remains.
I decided to cut an opening in the mower frame under the battery. This will enable me easy access to the trans reservoir cap. I completed this today.
Upon opening the cap I saw what appears to be a solid material like dirt. The tiny hole in the cap was plugged but easily opened with canned air!
I was really expecting to see a low level of oil but found the “dirt” instead. I have not attempted to try and remove (vacuum) it yet pending any advice I receive from the forum.
Has anyone seen this before and offer any suggestions?
Thanks so much,
Ski
Fixture Motor vehicle Red Gas Automotive exterior
Wheel Motor vehicle Fixture Wood Automotive lighting
Automotive lighting Motor vehicle Paint Automotive tail & brake light Car
Black Motor vehicle Red Wood Gas
Red Material property Gas Motor vehicle Auto part
Gas Auto part Metal Electric blue Carmine
· Super Moderator
Thanks so much,
Ski View attachment 2542668 View attachment 2542669 View attachment 2542670
View attachment 2542678 View attachment 2542679 View attachment 2542680
You will want to put a cover on there to keep dirt/grass from under the fender from coming up through.
Had some success. As you can see by the photos the dirt was captured by the plastic cup gasket under cap. Dirt must have accumulated over 20 years through the breather hole. I could not find a fill level mark inside the reservoir so I just added a little at a time. Just 8 oz of 20w-50w oil. Put everything back and ran it!! 4 mph out of the gate. Ran so much better!!
Next step will be to drain oil, measure, and refill. It will be trial and error on level in reservoir unless someone who knows posts!
Thanks for all the support.
Automotive tire Rim Wood Tread Gas
Camera lens Camera accessory Material property Gas Font
Fluid Food Automotive tire Drink Motor vehicle
Helmet Wood Gas Personal protective equipment Automotive wheel system
Automotive lighting Motor vehicle Vehicle door Material property Automotive exterior
Automotive tire Automotive lighting Wheel Motor vehicle Synthetic rubber
Motor vehicle Automotive lighting Material property Gas Auto part
