1 - 9 of 9 Posts
I already know what most of you have to say about the 12v converson...but i had to do it now for anyone reading this intrested in doing it i say no the kits they sell you do not fit and please dont cut your hood to make it fit i had to do alot of work to make it almost fit under my hood dont worry i didnt modify anything that i can not reverse..
I need help i dont study 12v electronics ... the alterator has a postive wire i ran that to the positive on my battery soo i got that far ...Now what to i do with the f termial and the r termial on the alterator???? is this enough information??? any help would make my night much easyer
I took my old generator to the local shop and he made it into an alternator. I have attached the the document that I am using to wire up my M.
Here are some notes about the drawing:
*The green square between the ignition switch and ignition coil is the resistor that most kits have in them (About $15)
*I had to buy a new 12V Voltage Regulator (My 6V was shot anyway) ($25)
*The drawing shows a positive ground, but its actually a negative ground
We used an alternator from a Datsun B-210 made by Mitsubishi. It's small Dia. gives good hood clearance. We used a ford electronic regulator also.
i converted mine and used the same old 6 volt starter.
dido, except the conversion was on an 8n Ford, but still used the same 6 volt starter.
my wd and 8n both used an old Delco 2 wire alternator, the two wires were just wired together, I don't recall were the wire ran, but I think it went to the alt gauge, then a wire to the one post on the ignition switch (had a car type ignition). Don't quote me on it though.
1 - 9 of 9 Posts
