My 48 8N had been hard to start. It would turn over but failed to start. I ran the battery down and recharged it. I took off the coil and distributor cap to clean them up. It started up! After a week it would not start. It was turning over but now just a clunk. I tried to jump start it by hooking up my car (12v) directly to the starter post and ground to the running board but just a spark. When I push the starter the solenoid clicks shut and the post on the generator gets hot if I do this on and off. The crank pully moves just a 1/8 inch. It seems like the starter is stuck as I can feel the starter move or rotates just a bit. :dunno::dunno: I want to buy a hand crank to see if I can turn the engine. I am trying to rule out weak 6 v Napa battery but cells show 3 balls or 75%. My charger on 6 v only has a 10 amp selection vs 2 and 10 for 12 volts, I don't want to cook the battery. Could this be a starter problem? I plan on buying a tune up kit with 437 autolite plugs, cap , points and rotor. I have the h10 champions now. Also thinking about a starter brush set. I have attempted to loosen the 2 long starter bolts. The outside one is 1/2 inch hex and moves, the inboard one is 7/16 and won't move. I sprayed PB blaster to loosen the rust but it little room since the block drain is near by. I have had the tractor for 4 yrs and this is the first problem. Any suggestions?
Bob :dunno:
Bob :dunno:
