I got this mounted to a X720 tractor, I've lubricated grease fittings on auger shaft as well driveshaft. I've checked gear box oil. I've sprayed lube on chain.
when I engage PTO it just seams it makes alot of noise down where driveshaft hooks to blower end, and where the chain is. I remember this last year, I thought maybe chain was a little loose, I checked and it seams to be ok. Does this sound normal? I'm just wondering people with same blower if yours does the same, and I have nothing to worry about. Or if something isn't right and should have it checked.
