47 inch chute deflector Modification
4177 Views 26 Replies 11 Participants Last post by  JD X728
Hi, I know this has been delt with on other threads but I'm pretty proud of myself for completing this mod so here is my story and some pics , if I can post them. Any questions, PM me.
Firgelli no longer makes the 4 inch stroke mini actuator with 15 lbs force so I opted for the 6 inch stroke, not taking into consideration that the body would also be longer. The pics will show how much longer and where I bolted the bottom to the chute. Fully open and Closed will not even use the full 6 inch stroke, way overkill but I was concerned about the force issue. again, 15 lbs is overkill, IMHO but it works. I bought a water proof Boat dpdt switch, a little bigger then usual but I wanted a larger switch for gloved hands. so far so good. I used 16 guage wire , again overkill but works great. I also installed a Custom Dynamics, magic block for pos and neg. These have a fuse installed already, and all you do is hook them to the battery post and put your wire end in and lock the orange lever down. DONE. If you want to add anything else, like Led work lights , You just push the wires in , add your on and off toggle switch and DONE. You don't have to go to the battery again . Pics of them and they work. They have four outlets so you have plenty of room. Hopefully the pics will speak for themselves, the thing works, Overkill yes, but I don't think it will fail anytime soon. Thanks for listening to the rant.
Jerry in wisconsin
21 - 27 of 27 Posts
Nice install Jerry really like those connection blocks wish I could have found something like that when I did my install, I went with the 8 lb actuator will let you guys know if it doesn't work out but it seems plenty strong enough. I also couldn't seem to find a two wire plug that was up my expectations so I went with a lighter socket from the boat yard and a modified shock cord.:thThumbsU
Excellent idea :thanku:
Hey Stepdross, Happy New year and that is really a slick way you did yours. that same type of connection with a water resistant trailer plug would work out great. I just used the 2 pin trailer connector, got it at the local hardware store as an afterthought when I was there for something else. Interesting to see how other guys do their setups. I would think that your 8 lb force actuator , would be enough. I couldn't get anything less in the six inch stroke mini and i just wasn't sure how much I would need. I suspect that the 8 lb is plenty enough. good luck in the white stuff this year.
Jerry in wisconsin
Hey Wooly, Happy New Year to you also and like you said, I can take on anything with the Big ol diesel, but it would be alot nicer if I had the
HEATED CAB :crybaby::crybaby::crybaby::crybaby:
Jerry in wisconsin
Happy New year to you as well Jerry, I looked everywhere around here for a two pin plug but couldn't come up with one almost bought two of the remote battery charger plugs and used them before I went to the local boat yard they had a very nice metal trailer plug but it was over $50. and I thought that perhaps I was getting a little crazy. Then he turned and said well if you don't want to spend that we have this 12 volt outlet for $5. end of story:trink40:
not sure a car lighter adapter is the best solution.
And you do not need a special plug, just two simple covered spades and lugs, waterproof is meaningless! With single connectors there is nothign to short, wet or otherwise!
these work perfect!
these work perfect!
Just wanted it to look a little better in the off season If it doesn't work out I already have half of the connectors on the back side of the outlet.
Jerry in wisconsin
Jerry,
That is a terriffic write up! Wow pictures and all, it's very good article.
Thanks for taking the time to shoot the pictures and write the post.
Jerry in Washington State.
21 - 27 of 27 Posts
