knifer94
i have a 4600 that leaks power steering fluid out the top of the housing at the steering wheel. i have put two new seals in it and they last a while then start leaking again. the shaft dose not seam to have a groove worn in it. the tractor has less than 700 original hours on it. any help. thanks, david
1981 Ford 1100 4WD
Just to clarify, the power steering fluid comes out just under the steering wheel, not down by the steering box?
The seal you replaced, isit the one at the bottom of the steering shaft, near the steering box?
1981 Ford 1100 4WD
Have you looked closely at the old seals, when you remove them, to see why they were leaking? I've replaced this seal on a Ford 2000 and it did the trick. So if yours is leaking again I would look for why they leak. Also check to make sure it's installed in the correct orientation, I don't remember if you can install it backwards.
