Thanks for all of the positive comments. I was a little scared to post up some pics b/c wasn't much to them. As far as the "no chains" question, I'm in the same position as most on this forum trying to find the "perfect combo" that works for their particular situation. No chains worked fine this time, but once again their wasn't much snow and no ice. I do however think I may need some more weight and/or traction if I were to get any significant snowfall or ice accumulation.
My probelm is this- My driveway is concrete and I could care less if chains were to scratch it up. I plow my 90 year old neighbor's driveway for free (which is relatively flat), but it is blacktop/sealed driveway and I would feel TERRIBLE if I left any unwanted marks.
My thoughts of options at this point (keep the rear weights and)-
1. Wheel weights/chains/ and possibly "re-seal" of neighbor's drive in the spring
2. Wheel weights/HDAPs
3. Wheel weights/ "rubber chains"
4. Loaded Ag/bar tires?...
5. Loaded turfs/HDAPs?...
I would just hate to put some money into a set-up that won't work. Any thoughts would be great...
I would choose #5 with all the weight I could hang on it
without
chains.
I struggled with this same problem on my X720 with my slopped driveway and I'm really please with my set-up, 6 suit case weight, rims weights and fluid in both Ag's.
First time out 3" of snow no ice and it worked great.
Second and third time there was ice underneath 4" of snow, and I could blow
snow up my drive with no problem.
If I really push it going up with the blower down and running, there's a slight
slippage, then I use the diff lock.
I have Ag tires only because that's what was mounted on my slightly used rims I purchased last fall. I think HDAP's would also work well.
Like I preach, use lots of weight especially without chains and you can't go wrong even on slops.
