I have a 4518 that has been in the family since new and always well maintained. The last few years however the mower has become increasingly difficult to crank and prone to stalling and generally seems to be down on power. The engine will crank and idle (somewhat) but any attempt to throttle up and the motor just dies. I can hear some backfire through the air cleaner. This mower has never really been in storage, it has been in use since new.
Compression checked out fine, 155 PSI on both cylinders. Spark plugs are new, correct NGKs. Battery is new. Fuel pump clicks as it should, flow rate of fuel at the carburetor looks good but fuel filter has not been checked or replaced. Research lead me to become suspect of the CDI module and the cold solder joints so I bought a cheap aftermarket CDI for testing. I can tell no difference between the factory CDI and the aftermarket one. The carburetor has been completely disassembled and cleaned, although there were no signs of varnish or buildup found. I did notice the linkage between the throttle and choke baffle in the carburetor was missing so a replacement was fashioned. The choke baffle return spring was also weak so an external spring was added. The choke appears to be working normally now.
Should I go ahead and open the factory CDI and inspect for weak solder joints? Finding no difference between the factory and cheap aftermarket unit leads me to believe they are either both bad or not the source of trouble. I've read of timing belt slippage, could this be part of the issue, especially with that backfire coming through the air cleaner? It is just odd because there are moments sometimes lasting multiple minutes where the engine sounds pretty good at idle, nice and smooth and no backfire (still can't throttle up though). These are rare these days, but it happens. If the timing belt was slipped I'd think it would be all or nothing. Just today it was running ok at idle and I managed to drive it around the yard at idle speed for probably 2 minutes before returning to the shop just as it was starting to bog down and sputter and then died, thankfully right back in it's parking space.
I posted a few YouTube recordings of the mower running if that is helpful for diagnosing what might be going on. Thanks everyone in advance!
May 10, 2022
May 10, 2022
May 10, 2022
