I started hearing a noise like a bearing going bad and traced it to the PTO clutch, I think. In getting to the bearings I have a couple of questions.
1. Which bearing is more likely to fail the one on the Pulley Assembly or the Ball Control Plate?
2. Can the bearing in the Pulley Assembly drive be replaced individually or do you have to replace the whole assembly?
3. In looking at the parts diagrams I see a ring that fits on the PTO clutch, Honda part 75119-758-801. However, I can't find a similar ring on the Pulley Assembly. Any ideas on where it is
4. If I have to replace the Ball Control Plate bearing how does the Plate Drive come off?
Thanks in advance
Rick
Thanks in advance
Rick
