Update,
Replaced the front crankshaft oil seal, rear crankshaft oil seal and the rear camshaft oil seal.
Still leaking out the rear crankshaft oil seal. Will have to do this one over. Here is what I will try.
Emery cloth the crankshaft to remove any bur or other possible issues.
oil the inner and outer areas of the seal again.
Press in with home-made press.
Should I use any RTV? Any grease, or just motor oil?
When I when to put in the replacement, there is an outside rubber ring on the seal. I can also see a groove inside the seal area of the lower block where this ring might fit into. While pressing the seal in, some of this ring came off and was not successfully pressed into the block.
Now, with the timing belt on, I can't tell if the leak is coming from the shaft area or the outside of the seal. Will try removing the timing belt and see if I can tell where the leak is occurring around the seal.
Anyone have any extra tips on how to accomplish this? I would prefer not to go at it a 3rd time.
