any engine with a rubber timing belt will have that tendency when the belt has stretched far enough. And given the 4514 is a 3813 block, crank etc, that one's a no brainer. But the 4518 timing belt is no more durable or stretch resistant than the 3813. Remember - it gives honda something to sell you on a planned basis. Gratefully, on the honda's there enough clearance between the piston crowns and the valves that you can slip in a deck of cards between the valves and pistons, regardless of timing belt position.
heckuva, even metal timing chains will stretch. Back when i mechanic'd at a dealership, Nissan (then Datsun) went from a double timing chain to a single timing chain (late 60s/early 7s), and 6-7 years later we saw the occasional engine job from chains jumping one or two teeth on the timing sprocket and helping valves meet pistons. That's when timing chain replacements became a standard service item on the recommended maintenance schedule. Before that, the chain's tensioner was the only maintenance item.
Nissan wasn't alone, don't think the other mfgrs didn't see that move as a good way to increase future parts & svc work sales - they all followed suit.
