21 - 34 of 34 Posts
When I got mine it was in ruff shape too. You did a great job looks good.
Discussion Starter #22
Nice I used a bed-liner spray on mine.
I do not recommend this.
I do like the teeth, where did you get those ? what are they? Are they too large ?
The Tooth Bar is from Titan Attachments.
They are large, but not too large. They are good for hauling stuff that doesn't fit in the bucket, which is most of the stuff that I've used it for. Plus, they are great for digging. I dug a patio 12" deep and then back filled with gravel.
The bucket is a life saver.
Here is a boulder that I moved. If I didn't have the teeth it wouldn't have fit and it helps get under it.
Discussion Starter #23
Ugg if I tried to lift something that heavy, make back wheels would come off the ground and I would be stuck. I really need to get a 4ws or a 4wd or more weight.
JD X585 owner
Nicely done with the paint job. Looks terrific. I need to mine.
Sent from my SCH-I545 using Tapatalk
You just need more counterweight. The tractor in the picture is 2WD.
Discussion Starter #27
x2 on the counterweight and you need to shim the hydraulics. Makes a world of difference.
X3 on the counterweight.
My MF1655 regularly lifted and transported payloads of 800 lb with 650 lb of rear end ballast. It takes over 1300 lb of payload to lift the rear wheels off the ground. (Done that more than a few times as well!)
Load the rear tires with Rim Guard. That will get you 140-150 lb of ballast. (An extra 250 lb of payload before the tires come up.)
I put ATV tires on the back and tubed them and filled them with water. I still need more weight. It frequently gets stuck trying to pick up mulch, riding on mulch. teeth would help also.
Discussion Starter #32
Are you sure I thought the x485's that have lug bolts in the front are 4ws, mine does not.
No sir...My x485 is 2wd and 2ws. I added the Special Edition front hubs and 10" wheels/tires.
These are the same wheels and tires that you would find on a x575 585 595 728 748.
Loader turned out great!! I've been looking for one and will do that same process when I get one.
Did you buy the wheels new or used? They add a nice touch.
Discussion Starter #34
Thank you.
The wheels, tires and hubs were all new including new rear tires, but original rear wheels.
21 - 34 of 34 Posts
