1 - 20 of 34 Posts
I spent some time restoring the bucket on my 45 loader. Sanded the rust and some loose paint and used several rattle cans to paint the bucket. Also sprayed some clear and added new decals. One 6 inch to the back of the bucket and a 3" on either side of the arms.
I was going to have it powder coated, but the $300 price tag made me rethink it and decided to paint it myself. I think it turned out pretty good. My wife said, "Now what are you going to do when you need to use it?"
Discussion Starter #2
One more
A couple more of the gx345 to get you thinking about winter.
Added 6" decal to the back of the cab.
Looks good! :thThumbsU
You don't powder coat something that is going to bang into rocks. Paint scratches and can get worn off requiring a simple sand and repaint to fix, but powder coat chips and moisture gets under the edges of the chip so that the ensuing rust can lift large patches of powder coat. The result is u-g-l-y, and the repair is to grind off all of the powder coat and rust patches and start from scratch.
Paint looks good. I agree on the powder coat being a bad option for this.
AKA Moses Lawnagan
I agree with Tudor 100% on powder coating. If you use a loader, it's going to lose its paint on the bucket. I don't really worry about the bare steel, if you use it often enough it stays polished. If you put it up for a while, then I'd use a spray bomb to coat the bare spots and keep the rust away.
I love those ripper teeth, did you buy them or make them? If you made them, what from?
Discussion Starter #10
I originally was going to powder coat it since it is powder coated from the factory. I agree, it's going to scratch off eventually, so spray cans were the way to go, plus it was a lot cheaper.
The bucket had missing paint when I bought it. Since then I have moved 40 tons of traffic bond for a retaining wall and patio and also the retaining wall block and pavers, so it has had some use. Not to mention removing the huge 300-400 lb boulders from where I built the wall and tons of dirt from planting a tree line.
BTW, the Tooth Bar is from Titan Attachments.
Looks sweet. How much time did you spend?
Discussion Starter #12
I power wire brushed and sanded for 2 hours then pressure washed and let dry.
By the afternoon I was spraying green paint in light coats letting it dry between coats.
Probably 8 hours total at that point.
Then I let it dry for several days and re-sprayed green again.
Then let it dry for several days and clear coated and is what you see today.
Wasn't too bad, just a lot of patience which I normally don't have.
A labour of love doesn't require patience. It's the main ingredient of the love package. :thThumbsU
Now everyone thinks you never worked it! :sidelaugh
Looks good, never hurts to maintain equipment.
Discussion Starter #17
Just great. Now we're going to get snow in August. Thank you very much.
Just doing a little preseason prep. Need to get it on the charger from sitting so long.
It will be here sooner than we think.
Discussion Starter #18
Looks nice. I've seen at least five 4 or 5 series garden tractors with loaders for sale this year and none of them are as clean as yours.
Thanks. I am like that with all my machines. Always cleaning or fixing something.
Discussion Starter #19
It's going to be hard to take that first bite into the dirt next time.
Nice I used a bed-liner spray on mine.
I do not recommend this.
I do like the teeth, where did you get those ? what are they? Are they too large ?
1 - 20 of 34 Posts
