1 - 14 of 14 Posts
i have an some attachement off a 318 and want to fit them on a 425. Can someone tell me the differences in the mounting. I need dimensions if at all possible
2 inches wider? Are the lignment holes in the same location? I want to know if I could just cut the brakcets off the blade and extend them out to fit.
Chris
Homeboy, I think that Tony is sporting a Johnny Bucket Sr. on his 425 and a front carry all on the 318.
Homeboy, I think that Tony is sporting a Johnny Bucket Sr. on his 425 .........
I dont think that is a JB Sr., unless he changed the design drastically. The JB Sr.'s mounting bracket is much, much smaller and the hydraulic cylinders are attached differently.
Here is a pick of the JB Sr. and you can see what Im talking about.
I think that may be a home made job, only Tony can tell us for sure.
Yep went to the site and couldn't find one that matched that setup. Well I thought it was......! Tony will have to let us know what brand that one is then, I looked at a couple of others and couldn't find it either.
What is that on the 425?
That is a Buckalu that we built. All aluminum material . total weight Is 127 lbs. It lifts 24" tilts to unload. I'll post a couple more pictures. The frame width is 2" wider on the 425 and the hole location is about 1 1/2 " more.
The black one is for the 140/300 Series They are full hyd; Lifting capicity over 800lbs if you want to brake your tractor'' Common sence about 200lbs
Tony, thanks for the update on that! Nice fabrication there! Doesn't look like your first time working with aluminum!!!:biglaugh:
1 - 14 of 14 Posts
